(API) Division Points N - points on calc. elem.
I have generated Force table using API:
and I got this Forces table in Robot:
but I would like to have Force table with additional division points like this:
I can achive this result by changing table columns to this option:
Can I change this option somehow using API and after that print result to temp file? I tried to use Configuration.SetFlag after Selection, but I do not know which flag should I use and with which value?
Regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Try  .....SetValue I_TCV_NUMBER_OF_DIVISION_POINTS,......
Rafal Gaweda
Hi, Thanks for answer.
Unfortunately it change this value:
but I do not want to change this value, but only change the radio button to second option.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
So I am afraid it is not implemented in API.
Rafal Gaweda
I can change this option to third radio button
using:
.Configuration.SetFlag(IRobotTableConfigFlag.I_TCF_GLOBAL_ANALYSIS_RESULTS_RELATIVE, 1);
