API : creating dimensionning families using the API and VBA
youssef_taamallahCZ4NM
hi ,
im new to using the api , and so far im meeting a huge issue with trying to create dimensionning families and i cant seem to find a solution for it .
If Not RobApp.Visible = True Then
Set RobApp = Nothing
MsgBox "Ouvrez une session de Robot PCI "
Exit Sub
RobApp.Project.Structure.Groups.Create I_OT_BAR, "GR 2", "1 2"
idx = RobApp.Project.Structure.Groups.Find(I_OT_BAR, "GR 2")
End Sub
Stephane.kapetanovic
hi @youssef_taamallahCZ4NM
the groups of bars and those corresponding to the steel design are not the same.
Find a copy of "Robot API SteelDesign.pdf" and take a look to this following link API: Get Data to Create Dimensioning Groups
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
i cant seem to find how in the documentation though , im not familiar enough with this i guess . can you point to me where to look for exactly ? @Stephane.kapetanovic  , like a simple exemple  ?
Romanich
Hi @youssef_taamallahCZ4NM ,
I think you should store the group first:
Dim RGR As robotgroup
''your code'''
Set RGR = RobApp.Project.Structure.Groups.Get(I_OT_BAR, idx)
RGR.Store
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
i was able to make it happen using this code :
Dim RDmServer As RDimServer
Dim RDmStream As RDimStream
Set RDmServer = RobApp.Kernel.GetExtension("RDimServer")
Dim RDmGrp1 As RDimGroup 'object of the 1st group
Dim RDmGrpProfs As RDimGrpProfs 'collection of sections for design
Dim GroupNo As String ' group’s number
RDmServer.Mode = RobotOM.IRDimServerMode.I_DSM_STEEL
Set RDmGrps = RDmServer.GroupsService
GroupNo = Range("B" & I)
Set RDmGrp1 = RDmGrps.New(0, GroupNo) ' creates a new Object of the group with default settings
RDmGrp1.Material = "ACIER E28 D9000 ACIER E28 D9000"
RDmGrp1.Name = Range("D" & I)
Set RDmStream = RDmServer.Connection.GetStream
RDmStream.Clear
RDmStream.WriteText (Range("E" & I)) 'list of members
RDmGrp1.SetMembList RDmStream
Set RDmGrpProfs = RDmServer.Connection.GetGrpProfs
RDmGrp1.SetProfs RDmGrpProfs
RDmGrps.Save RDmGrp1
But im having issues defining the right material for my groupe .
I bascially need to ask robot to use either S235 or S355 steel .
but the specific line that makes this happen in the documentation is :
this doesnt seem to work ,  does anyone know how i can make it happen ?
Thanks a lot for the advices .
you are right, RDimGroup accept a property Material in string format.
if you have a material already created in your project nammed "S235" or "S355" for example, you can use it.
Best regards
