(API) Create Cladding from coordinatres
Message 1 of 16
I am trying to develop a macro in order to create a cladding from coordinates.
When I execute this maccro, an error page appears indicating: "Objet requis".
Here is the macro:
Sub Create_cladding()
Dim monobjet As RobotObjObject
Dim moncontour As New RobotGeoContour
Dim monsegment() As New RobotGeoSegmentLine
Dim i As Long
ReDim monsegment(1 To 4)
monsegment(1).P1.Set 0, 0, 0
moncontour.Add monsegment(1)
monsegment(2).P1.Set 1, 0, 0
moncontour.Add monsegment(2)
monsegment(3).P1.Set 1, 1, 0
moncontour.Add monsegment(3)
monsegment(4).P1.Set 0, 1, 0
moncontour.Add monsegment(4)
moncontour.Initialize
Set monobjet = robapp.Project.Structure.Objects.Create(1)
monobjet.Main.Geometry = moncontour
monobjet.Main.Attribs.Meshed = False
monobjet.Main.Attribs.DirZ = 0 ' axe local
monobjet.Main.Attribs.SetDirX I_OLXDDT_CARTESIAN, 1, 0, 0
monobjet.Initialize
monobjet.Update
moncontour.Clear
Set monobjet = Nothing
Set moncontour = Nothing
ReDim monsegment(1 To 1)
Set monsegment(1) = Nothing
End Sub
Thank you for your help!
Erwann
Replies (15)
Message 2 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi Erwann,
Your code creates Contour (Object).
You need to apply Cladding Label to this Object
Example code below
RobApp.Project.Structure.Objects.Get(obj_number).SetLabel I_LT_CLADDING, "Two-way"
In French "Two-way" is "Deux directions" 🙂
Rafal Gaweda
Message 3 of 16
daniilZSZ8N
Hi Rafal,
Working in Python sandbox 2.6
I'm trying to apply meshing to the contour in Robot but it isn't working
Everything else is working fine, labels,etc, just can't convert a contour to the analytic panel.
app = RobotApplicationClass()
project = app.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
ProjectPrefs = project.Preferences
bars = structure.Bars
objects = structure.Objects
nodes = structure.Nodes
fn = objects.FreeNumber
points = app.CmpntFactory.Create(IRobotComponentType.I_CT_POINTS_ARRAY)
points.SetSize(4)
points.Set(1,0,0,0)
points.Set(2,1,0,0)
points.Set(3,1,1,0)
points.Set(4,0,1,0)
objects.CreateContour(fn, points)
ro = objects.Get(fn)
ro.Main.Attribs.Meshed = True
ro.SetLabel(IRobotLabelType.I_LT_CLADDING, "Two-way")
Message 4 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @daniilZSZ8N
You have to decide whether You want to have panel (meshed) or cladding.
Last command is to create cladding.
Rafal Gaweda
Message 5 of 16
daniilZSZ8N
Oh, yes, I just wanted to say that none of them are working.
I tried the way described officially here https://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/sfdcart...
and your code with selecting by type and converting in a loop.
Nothing. Still contour.
Can it be the Robot 2020 API issue?
Message 6 of 16
daniilZSZ8N
Boom!
The answer is
ro.Initialize()
ro.Update()
Message 7 of 16
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @daniilZSZ8N
It has nothing to do with meshing 🙂
Rafal Gaweda
Message 8 of 16
durducgeorge
when i try to convert the contour into cladding, it doesn't work (I tried in C#, maybe in vba it works)
Message 9 of 16
Stephane.kapetanovic
hi @durducgeorge
try this
Sub AssignCladdingDiectionToContour()
  Dim RobApp As IRobotApplication: If NotReady(RobApp) Then Exit Sub
  Dim obj As RobotObjObject
  Set obj = RobApp.Project.Structure.Objects.Get(obj_number)
  obj.SetLabel I_LT_CLADDING, "Direction X"
  obj.Update
  RobApp.Project.ViewMngr.Refresh
  Set RobApp = Nothing
End Sub
RobotApplication RobApp = new RobotApplication();
RobotObjObject obj = (RobotObjObject)RobApp.Project.Structure.Objects.Get(obj_number);
obj.SetLabel(IRobotLabelType.I_LT_CLADDING, "Direction Y");
obj.Update();
RobApp.Project.ViewMngr.Refresh();
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 10 of 16
durducgeorge
Hello S.Kapetanovic,
Thank you! It works!
Message 11 of 16
heau_a
Hello Mr.kapetanovic,
I'm reaching you regarding an issue that I encoutered when I tried to apply claddings to some coordinates from a CSV file. Explaining from scratch, I have a csv file with lines giving id type and coordinates of each pieces and as a test we assume that they were all claddings. The goal was to transform it as a list of sublists of each materials and apply the claddings on each. Therefore, I used Dynamo in Robot directly to try Python Scripts but I had so many problems with RobotOM and class usage. I don't know if the best option is to create directly a Robot Add-On or to try again via Dynamo Python and instanciate a new Robot cause I saw on internet that it was impossible to save an old instance of Robot and that we were forced to do RobotApplicationClass().
I can give you an example of my code so you can analyse me errors for now and tell me what could be improved cause actually I have a lot of problems and tried a lot of things to make it work.
import clr
clr.AddReference('Interop.RobotOM')
import RobotOM
import time
# Entrée : liste de claddings sous forme [ID, label, x1, y1, z1, x2, y2, z2, ..., xn, yn, zn]
liste_claddings = IN[0]
# Nouvelle instance de Robot
robot = RobotOM.RobotApplicationClass()
robot.Visible = True
robot.Project.New(RobotOM.IRobotProjectType.I_PT_FRAME_3D)
time.sleep(0.5)
structure = robot.Project.Structure
factory = robot.CmpntFactory
results = []
def get_free_object_id(start=1):
    free_id = start
    while True:
        try:
            if objects.Get(free_id):
                free_id += 1
            else:
                return free_id
        except:
            return free_id
for ligne in liste_claddings:
    try:
        ID = int(ligne[0])
        nom = ligne[1]
        coords = ligne[2:]
        if len(coords) < 9 or len(coords) % 3 != 0:
            results.append(f"Cladding {ID} ignoré : mauvais nombre de coordonnées")
            continue
        nb_pts = len(coords) // 3
        pts = factory.Create(RobotOM.IRobotComponentType.I_CT_POINTS_ARRAY)
        pts.SetSize(nb_pts)
        for i in range(nb_pts):
            x, y, z = coords[i*3], coords[i*3+1], coords[i*3+2]
            pts.Set(i + 1, x, y, z)
        obj_id = get_free_object_id(ID)
        objects.CreateContour(obj_id, pts)
        obj = objects.Get(obj_id)
        if nom and structure.Labels.IsAvailable(RobotOM.IRobotLabelType.I_LT_CLADDING, nom):
            obj.SetLabel(RobotOM.IRobotLabelType.I_LT_CLADDING, nom)
        obj.Update()
        results.append(f"Cladding {ID} créé")
    except Exception as e:
        results.append(f"Erreur cladding {ligne[0]} : {str(e)}")
OUT = results
This code may seem good but after the execution I'm gonna have the error "Unable to find reference interop robot om " even I have the dll file and after fixed it they say the SetSize is not usable for this class object.
Thank you in advance,
M.G
Message 12 of 16
hi @heau_a
Have you tried looking at more specialized forums focused on Python and Dynamo?
Please note that this forum is not intended for troubleshooting or support related to software installation and system configuration.
The issue you're encountering ('Unable to find reference interop RobotOM') is not directly related to the API itself, but most likely stems from how the RobotOM library is linked or registered within your development environment, particularly the integration between Python, Dynamo, and your IDE.
Make sure the RobotOM COM library is properly registered and accessible from your scripting environment.
Also, ensure that the Robot installation path is either included in your system PATH environment variable or explicitly added within your script before attempting to load the COM object.
However, you will find several threads here discussing Python, such as which version to use, common issues with COM type casting in Python, and even some complete working scripts.
Best Regards
Message 13 of 16
heau_a
Yes already try this forum, two topics of 2018 and 2022 without any response...
We also think that it could be due to Dynamo link with Robot and will try SDK addin instead.
Thank you !
Message 14 of 16
hi @heau_a
I don’t know your industry well, but what you’re doing is quite simple from a programming point of view. However, the chosen approach may introduce unnecessary complexity. While the example code can help you understand how Dynamo works, it’s worth evaluating whether this setup is truly the most efficient for your goals.
Best Regards
Message 15 of 16
heau_a
I'm reaching you cause I've been programming an Add-In recently for a purpose and everything was working well before I decided to change the name from MyAddin to my custom name. The fact is that I thought everything will be fine I could just delete one and install the new one with the different name. But, since I did that when I add the new one I have 2 add-in with some japanese characters. The fact is one is blocked I can't do anything and the other one is linked, as you can see in the photo but I have my function but it's not usable.
So yeah I'm a bit upset cause I shouldn't change the name and I saw on some posts that it was an option with the regedit that saved the old addins names and GUID. I did everything trying to delete old GUID Assembly Keys and assign a new one but nothing changed.
Message 16 of 16
hi @heau_a
the issue you're encountering is unfortunately completely unfamiliar to me. For an unexpected issue that occurred following a recommended automated procedure after forcing an add-in into the Windows registry and renaming it, Autodesk Support will be best placed to assist you.
If this situation were more common, I’d suggest removing all existing shortcuts and recreating them manually, verifying each one works correctly. Add-ins Manager Dialog Box
By the way, we favor a portable architecture for our free standalone executables, meaning no system integration, no third-party dependencies, and no installation required.
I sincerely hope you're able to find a solution quickly.
Best Regards
