API - Combination type
I need to extract combination type through API code. I can't figure it out with forum post's.
What i really need is a Excel column with combination type (ULS, SLS:CHR, SLS:FRE, SLS:QPR, ACC) like we see in Load Combination tables.
Best regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Using API you can get main types only : ULS, SLS, SEIS, ACC
See:
http://forums.autodesk.com/t5/robot-structural-analysis/editing-load-cases-in-excel-api/m-p/3929901#...
So to get all types you have to dump table this (general) way:
http://forums.autodesk.com/t5/robot-structural-analysis/api-macro-for-dumping-all-opened-tables-in-r...
or see attached example for opening and dumping combination table
Rafal Gaweda
