API - closing views
API - closing views
klavs
Message 1 of 8
API - closing views
klavs
I'm creating alot of temporary views for screencaptures which I'm adding to the report using the API.
How do i close the temporary views using the API?
Replies (7)
Message 2 of 8
Stephane.kapetanovic
 Hi klavs,
 You can reuse the same view, pic your capture and reset the view for another.
One is enough.
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 4 of 8
klavs
Thanks that did the trick
Message 5 of 8
jazlik
Hey! The link @Rafal.Gaweda sent is not working for me. Can somebody direct to me to it? I am in the same situation as the author of the post!
I am creating the view and later trying to close it/delete it as it slows down Robot quite a lot with so many views:
var panelSelection = GetPanelSelection(panelGroupName);
var rsaView = _rProject.ViewMngr.CreateView(IRobotViewType.I_VT_MAPS_ON_FINITE_ELEMENTS) as IRobotView3;
var selectedCombinations = GetCombGroupSelList(_rStructure.Groups, combType);
var getObjectsInView = rsaView.Selection.Get(IRobotObjectType.I_OT_CASE);
getObjectsInView.FromText(selectedCombinations);
rsaView.Selection.Set(IRobotObjectType.I_OT_PANEL, panelSelection);
var scrCaptureName = $"{panelGroupName} - {resultName} ({combType})";
CaptureRsaView(rsaView, scrCaptureName);
rsaView.Visible = -1;
Marshal.ReleaseComObject(view);
rsaView = null;
Message 6 of 8
hi @jazlik
Community content was recently archived. We're working to restore the discussion threads, but they might remain unavailable for a while. Support us here: https://forums.autodesk.com/t5/robot-structural-analysis-forum/community-content-archiving/td-p/1319...
Views can be closed like this:
Sub CreateViewAndCloseIt()
  Dim RobApp As IRobotApplication: Set RobApp = New RobotApplication
  Dim View As IRobotView3
  With RobApp.Project.ViewMngr
    Set View = .CreateView(.GetView(1).Type)
  End With
  With View.Window
    .Activate
    .State = I_WS_MAXIMIZE
    .SendMessage &H10, 0, 0
  End With
  Set RobApp = Nothing
End Sub
Best Regards
Message 7 of 8
jazlik
Hey @Stephane.kapetanovic  thank you! Was new RobotApplication created here on purpose? Or was it just for having access to ViewMngr for creating new View?
Message 8 of 8
Hi @jazlik
The codes published here are for demonstration purposes.
Best Regards
