(API) Changing the bar type
dagmaraxf
Message 1 of 11
dagmaraxf
How can I change the bar type using the API (please see the screenshot below)? I have already created bars in the project whose type is "N/A" and I would like to have a RC beam. Do I have to create a beam instead of a bar at the beginning?
I would appreciate your help.
Replies (10)
Message 2 of 11
Stephane.kapetanovic
hi @dagmaraxf
type (Steel beam EC3) is used for design.
' with Bar as RobotBar and Existing Label "Steel beam EC3" (to be created in other case)
Bar.SetLabel IRobotLabelType.I_LT_MEMBER_TYPE, "Steel beam EC3"
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 3 of 11
Note that this also works for R / C types
Bar.SetLabel IRobotLabelType.I_LT_MEMBER_TYPE, "RC Beam"
Message 4 of 11
dagmaraxf
@Stephane.kapetanovic
Yes, you are absolutely right, thank you. I was confused by the mention in the API: Member type for steel/aluminum and timber design.
Message 5 of 11
dagmaraxf
Hi @Stephane.kapetanovic maybe you know the solution to my next problem. I would like to change the settings of Calculation Parameter Definition.
I try :
structure.Labels.GetLabel(IRobotLabelType.I_LT_MEMBER_REINFORCEMENT_PARAMS, "standard").Data but gets an error. However, with the same syntax only with "I_LT_MEMBER_TYPE" the code works. Is there any other way to access these settings?
Message 6 of 11
hi @dagmaraxf
try these links
https://forums.autodesk.com/t5/robot-structural-analysis-forum/provided-reinforcement-api-robot/td-p...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-how-to-get-bar-reinforcement-resu...
Best regards
Message 7 of 11
dagmaraxf
Thank you for your help, I have already studied the links and my calculation of the required reinforcement works. However, while "bars.Get(1).SetLabel(IRobotLabelType.I_LT_MEMBER_REINFORCEMENT_PARAMS, "standard")" works fine, I don't know how to modify the "standard" parameter set (or create a new one, "Create" does not work). I think I should refer to "IRBestCalcParamsDataDoubleValue" but I don't know how.
Message 8 of 11
See messages 10 to 13/29 on second of previous links.
Message 9 of 11
stefanyC6JZ7
Hi @dagmaraxf
Could you upload the code of the creation of bars, including how you assigned section, material, and releases?. Currently I am trying to create bars with version CPython3, I just managed to create bars but tey are missing the properties. Thank you in advance.
Best regards,
Stefany
Message 10 of 11
dagmaraxf
from RobotOM import *
from System import Object
import math
from time import gmtime,strftime
from math import sqrt
ConcreteClass = IN[0]
B = IN[2]
H = IN[1]
NameS = str(H*100)+"x"+str(B*100)   #Section Name
B = B*1
H = H*1
application = RobotApplicationClass()
project = application.Project
structure = project.Structure
results = structure.Results
bars = structure.Bars
rbars = results.Bars
labels = structure.Labels
nodes = structure.Nodes
loads = structure.Cases
app = RobotApplicationClass()
app.Project.New(IRobotProjectType.I_PT_FRAME_2D)
#Geometry
structure.Nodes.Create(1,0,0,0)
structure.Nodes.Create(2,8,0,0)
structure.Nodes.Create(3,16,0,0)
bars.Create(1,1,2)
bars.Create(2,2,3)
#Supports
Support = labels.Create(IRobotLabelType.I_LT_NODE_SUPPORT,
"Przegub przesuwny")
Support.Data.UX = 0
Support.Data.UY = 1
Support.Data.RY = 0
labels.Store(Support)
nodes.Get(1).SetLabel(IRobotLabelType.I_LT_NODE_SUPPORT, "Przegub")
nodes.Get(2).SetLabel(IRobotLabelType.I_LT_NODE_SUPPORT, "Przegub")
nodes.Get(3).SetLabel(IRobotLabelType.I_LT_NODE_SUPPORT,
#Section
lab_serv = labels
sec = lab_serv.Create(IRobotLabelType.I_LT_BAR_SECTION, NameS)
data = sec.data
data.ShapeType = IRobotBarSectionShapeType.I_BSST_CONCR_BEAM_RECT
nonst_data = data.concrete
nonst_data.SetValue(IRobotBarSectionConcreteDataValue.I_BSCDV_BEAM_B,
B)
nonst_data.SetValue(IRobotBarSectionConcreteDataValue.I_BSCDV_BEAM_H,
H)
data.MaterialName = ConcreteClass[0]
data.CalcNonstdGeometry()
lab_serv.Store(sec)
bars.Get(1).SetLabel(IRobotLabelType.I_LT_BAR_SECTION, NameS)
bars.Get(2).SetLabel(IRobotLabelType.I_LT_BAR_SECTION, NameS)
Sorry it took me so long to write back. I am inserting the code.
Message 11 of 11
stefanyC6JZ7
Hi @dagmaraxf
Thank you very much for your response.
Best regards,
Stefany
