(API) Analysis parameters - Combination Sign - Changing spectral case main mode
TimoKet
TimoKet
Is it possible to change main mode number at combination sign table within analysis parameters via API? Could not find any examples of this.
Stephane.kapetanovic
hi @TimoKet
taking the example of your case X,
below is an example that may help you
RobotSimpleCase RCase = RobApp.Project.Structure.Cases.CreateSimple(1024, "Spectral_X",
   IRobotCaseNature.I_CN_SEISMIC, IRobotCaseAnalizeType.I_CAT_DYNAMIC_SEISMIC);
RCase.MainMode = 7;
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
TimoKet
Thank you @Stephane.kapetanovic! Answer was way more straightforward than what I expected 🙂
