AISC Allowable stress Increase
stef.niemczyk
stef.niemczyk
Dear Artur,
I seem to be having a problem with the 33% Allowable Stress Increase per AISC 9th Edition. Ticking the option doesn't seem to change anything if we check the calculation note post calculation.
I have attached an excel sheet showing the calculaiton results for a same beam. the first one on the left is without secondary stresses and no stress increase. The second on the right is with secondary stresses and with stress increase.
In both cases, the allowable Fa and Fv are the same.
can you check on that and let me know if it's something that I'm not getting right or issue with code check?
thanks
stephane
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @stef.niemczyk
Could you attach the corresponding Robot model too?
Artur Kosakowski
stef.niemczyk
Artur
Sure, See Attached. The structure in question is an Offshore Drilling Derrick and we verify the compliance to AISC 9th edition against a set of combination of given loads (Dead, Live and Wind).
The beam I was referring to in the excel file i sent earlier was Beam 266, so you can link to something.
Hope this helps.
best regards
Stephane
stef.niemczyk
Hi Artur
Gentle follow up on this topic please.
Thanks and regards
Stephane
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @stef.niemczyk
I'm keeping it on my to do list it has to wait till I'm able to meet with the development team. I'm sorry for not being able to provide you with the answer yet but I will update this topic the moment I have any new information.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @stef.niemczyk
The 33% of allowable stress increase applies to wind and seismic loads only
If for bar 266 which you focused on you select e.g. 3019 combination which include a wind load case you can see that there is a difference when you have this option switched off (left) on on (right):
When you design against a combination with neither wind nor seismic loads the results are the same (with no stress limit increased) for both sensations (e.g. for 3012.png)
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
