Adjust / Edit / Modify the grids
Lieu_Vo
Lieu_Vo
Could you please help me to adjust grids in RSA?
For example, I want to change the position of grid 3 form 7.0m to 7.5m.
Thanks all!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Lieu_Vo
You can do this in this way:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Lieu_Vo
Thanks, @Artur.Kosakowski,
But, I think Autodesk add Modify button in the Structural Axis which make easier for users.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi  @Lieu_Vo
In this dialog you can create a new and then delete the no longer needed axis:
Artur Kosakowski
