3D Solid - object offset from mesh
rokas_varanauskas
rokas_varanauskas
I have a 3D model where one volumetric object keeps moving away from generated mesh, see image below
In some cases volumetric object returns to it's correct position but then moves again after say model generation or re-run of analysis. When selected, FE mesh get's selected, so the elements are connected, not separate.
I have attached model to investigate. Please let me know if there is fix or workaround.
Rokas
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @rokas_varanauskas
1. open file in repair mode
2. delete meshes
3. mesh model
4. run model generation
Rafal Gaweda
