2D Truss analysis problem
Message 1 of 13
I started modeling a steel 2d truss as shown in the first picture and the results were true and actuate
but when I add columns under the truss as shown in the second picture the analysis changed
Knowing that I am using 2d truss type of structure also I tried to use 2d frame it also has the same problem
all the members are (simple bar)
I'm sure that there is a solution for this problem
Waiting for comments šŸ˜„
Accepted solutions (3)
Replies (12)
Message 2 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
As far as I can see you just transferred the supports from the truss model to the bottom of the columns whereas you should keep the same boundary conditions at the columns' tops (as releases) instead.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 3 of 13
You mean that I should keep the supports in the original location ???
Message 4 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
No, what I meant was that you should define releases which correspond to the original supports at the top of the columns in your second model as by default the connections among the columns and the truss are fully fixed.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 5 of 13
Muhammed.OPERA
Hi @Artur.Kosakowski
I think the results will change even if you have made a releases to the top of the columns.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 6 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Muhammed.OPERA
Why not to run a quick test? Smiley Wink
Artur Kosakowski
Message 7 of 13
Could You show me the Fx Digram ?
Message 8 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
It is actually displayed on the picture I attached Smiley Happy
Artur Kosakowski
Message 9 of 13
 i see that but i want to see the values of the forces in members
i try to solve this problem by make robot understanding that the hole members of structures are tension/compression members by :
Geometry ==> Additional Attributes ==> Advanced Bar Properties
then select all the members and press  ok but the values of reactions still different
Message 10 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
You can't do this for chords.
Artur Kosakowski
Message 11 of 13
you mean that the method i apply is correct but i should select specify members except the cords??
Message 12 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Cords and columns Smiley Happy
Artur Kosakowski
Message 13 of 13
Thank you guys for the help
The problem solved
summary for the solution :
1-Use 2D frame type of structure
2-Use tension/compression members by :
3-Release for the column.
Finally Thanks šŸ˜„
