The change in the display of core walls diagrams which I was explaining in this topic has been introduced in HF1 for RSA 2019.
Due to the change in the averaging method the values are now more accurate and the diagram shape is better ![]()
The display in the center of the last rows of elements indicates from where the values are taken but this location actually means that they are more accurate than the ones from the edges. This is not relevant to the change of the averaging method done in the HF1 .
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
