while placing structural columns at grids the last step goes wrong , On the Multiple Selection panel, Finish button didn't appear ! so i can't keep columns at grids as needed ! hope you can help and here is youtube link for this issue from my pc
http://www.youtube.com/watch?v=FPEbyNfB4GY
Solved by Joe.Charpentier. Go to Solution.
Ribbon not updating is an issue faced by many people and usually this is because you have an update missing. I don't know what is the exact update but if you do a search here on the forum you'll find what you're looking for.
Hope this solves your issue.
When posting an issue, it is usually helpful to include the version of Revit you are using, as well as any update release, if possible.
The issue where the contextual tab does not update has been discussed before- as Ali says, this is an issue that has been resolved with Revit updates.
For Revit 2013, you need to be on the latest Update Release- UR2:
For Revit 2012, there is a hotfix:
Joe
Ali , thanks alot for your help
joe , I'll take your words in mind the next time I add a question, I appreciate your help thanks for you sir ^_^
