Hi all,
I am trying to draw the stirrup for column like the following photo. May you show me how to draw it!!
Thank you so much.
Solved by bjoern_teutriene. Go to Solution.
You need to draw manually, draw seperate for rectangle & seperate rebar for diagonal.
you can create a fully reinforced column with Autodesk Revit Extensions as you can see in the picture below. There you can add many different types of additional stirrups. The extension is for free.
Kind regards
Björn Teutriene
