Revit Structure
Revit Structure
Post 1 of 3
How-to cut steel beam ends
1054 Views, 2 Replies
11-07-2012 10:58 AM
I have sloped steel w-beams connecting over HSS sq. columns - the colums and wall they are in are not perpindicular to the beams. (The intersect at an angle)
I have two questions. 1. What's the best way to cut the beam ends so that the cut end is parallel to column face and wall, and...2. how do I cut beam end face so that it is plumb cut to col. face and not perp. to beam slope?
26 Kudos
18 Solutions
Post 2 of 3
Re: How-to cut steel beam ends
11-08-2012 05:44 AM in reply to: Shawn
Hi Shawn,
Try using Refernce lines to Trim the Ends of the Beams at the Columns Lines and tails.
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
Post 3 of 3
11-08-2012 10:46 AM in reply to: VWD-MLM
Thank you... but I think i need a bit of schooling on how to create and use reference planes and lines.
SG
Post to the Community
New Post
Announcements
Community Alert | The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
