Hello, I would like to know if you can export to *. Dwg drawing in Revit, having the textures of walls and lines of walls with different layers.
If it is possible could you explain me the steps?
thanks
Solved by kathryn.langan. Go to Solution.
With the standard export settings, the outlines are exported to A-WALL and the patterns to A-WALL-PATT. You can adjust those layers in the export settings dialog: Layer Mapping for DWG/DXF Export. Does that help?
