Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Zoom - Hidden elements issue
2 REPLIES 2
993 Views, 2 Replies
Hi!
When I zoom out, lines that must be hidden becomes visible. So, when I plot the drawings that lines are plotted too under the roof... but that is incorrect!
The following screenshot shows the same view with differents zoom's levels...
Can you help me?
2308iFFBE09B9A1AF8714
2 REPLIES 2
kathryn.langan
The hidden lines are just a limitation of regenerating the graphics. Depending on the thickness of the lines and the zoom factor, the hidden lines can show through. This shouldn't affect your actual output though - if you check a Print Preview, it should display as expected:
2380iA4F7947926197BFE
2382iACEA9F543BAA6633
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
in reply to: kathryn.langan
Thank you Katie!
Forma Design Contest
