Work space is not visible
I am using revit 2018
As you can see from the attachment i can not see anything on the working space even when i use any command it shows its working but i csnt see anything it shows something when i hit render
Have you drawn anything yet?  Did you try Zoom Extent (ZE)?
Yes i have drawn walls but there is nothing that i can see and i have also
tried to zoom to fit but still cant see anything although when i split the
the windows it shows every thing but again when i try to resize the window
it becomes blank is there anything that i can do ?
aRcHiTeCt.JM
.... create a new project and try again
...  or is this happening in every project and familiies?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
It is happening in every project.
aRcHiTeCt.JM
... hi @Anonymous
... did you try with the visibility settings
.... try these troubleshooters
Use this checklist to troubleshoot why objects are not visible in a view.
Typically, when you cannot see an object as expected in a view, the issue is an incorrect visibility setting. Try to recreate the error in a new empty project. This process can help to isolate many crossover visibility issues that arise in phasing and family creation.
Start with the following strategies.
If you are still unable to locate the missing object, proceed through the following checklist to determine the source of the issue.
Check settings for the element or its category
Check view properties and related settings
Check additional conditions
aRcHiTeCt.JM
REVIT EXPERT ELITE
