Why isnt this wall being detected
Hello to everyone,
I would like to know if someone knows why this wall isn´t being detected... I drew it on the 2d blueprint yet it doesnt conect with the one that I have on the 3d Model. You can check the picture of this situation throught the picture that I am uploading.
best regards
Luiscko
Ca you be more specific because i do not understand your problem with the information that you give and the attach photo.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
ennujozlagam
hello, what do you mean wall isn´t being detected can explain more? or try to check your phasing for that wall. thanks
Yes, the wall that clicked on 3D is the same as the one that I have in 2D, although it doenst show up at the 2d view.
twebb4CYQY
be sure it's on a visible workset, and that it's a bearing (structural) wall
