Why can't I create vertical columns in section views, elevations etc?
Hi, I'm trying to recreated a drain that was made in HSS so I'm using structural columns but i'm having a hard time understanding how or why a vertical column cannot be placed in a section view as you would for piping? I have created model lines and can place the slanted columns but cannot select the model lines in neither 3D view or section. If I insert a ''slanted'' column on the vertical model line, it just skews my HSS and makes the faces of the drain not parallel with each other and slanted does not offer the option of rotating after placement. What approach should I be taking to recreated this? Thanks
