When open IFC file in Revit shows nothing like the file is empty
soonhui
Advisor Advisor
soonhui
When i open my ifc file in revit, it shows nothing and seems like the file is empty.
I used these steps below to open my IFC file:
  1. Create a new revit model file
  2. Select template file > Metric construction template
  3. Click insert tab > link ifc
  4. When open it shows nothing
But when I open the IFC file in other BIM software like BIM Vision, the pipes are all shown.
Is there any solution for this?
The IFC file is here
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
robertwmerriman1
Hi @soonhui
I'm not at my machine but have you checked the visibility graphics? When we open a structural IFC file the columns don't  show because they are on the category Colums not Structural Colums which is set to off
Try turning on all categories to see if they appear
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
L.Maas
In my case it shows up (Revit 2020) when linking in a file
Note that I changed the view range to get it into view on a floorplan
Left bottom of the screenshot is where the origin point is situated
Louis
Please mention Revit version, especially when uploading Revit files.
Mohamed-Nassar
check the IFC file with navisworks to check the file isn't empty from data
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
soonhui
i am currently using revit 2021.
i have tried your suggestion but still unable to show the floor plan.
would you mind explain the steps in detail especially on how to change the view range to floor plan.
Ngu Soon Hui
ennujozlagam
your LINK IFC file is higher than the levels go to 3D view and move your IFC to 1st storey level. see attached file and see if helps. thanks
