Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Weld symbol family edits
18 REPLIES 18
Message 1 of 19
LyleHardin
7243 Views, 18 Replies
Wow... I figured I'd edit Revit's weld symbol to look more like ours by changing the size of the flag, the all around circle and the fillet triangles. Not so easy...
The flag was easy enough, but now the solid fill does not show. For a while it showed up in 3 places.
When I change the size of the circle, the end of the leader moves.
When I open the Fillet triangle to edit, nothing shows up. No triangle.
I've not even tried any of the other welds (flush, field, back, etc.)
I'm trying to convince a Project Manager that Revit is the way to go, but I know he will want most of the drawing to look like our AutoCAD drawings and the Weld symbol is one of my last challenges.
This weld family is different than most of the other families I've tackled and I don't see much help on line about it.
Any tips?
18 REPLIES 18
Message 2 of 19
Sahay_R
in reply to: LyleHardin
Can you share a file please?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 19
LyleHardin
in reply to: Sahay_R
Attached is a .rvt file for you to check out. The family is above the dashed line, and our AutoCAD blocks are below the dashed line. We're sticking with Arial for the font in Revit. So, this is what I have for now.
I was able to finally get the fillet and flag close to the right size, but whenever I make the all around (circle) smaller, the arrow moves as shown in my first post. I also bet they will want the overall length of the symbol shorter. I've not tried that yet.
Thanks for your time!
Message 4 of 19
Sahay_R
How small do you need the circle to be? Right now it has a radius of 3/32"
Rina Sahay
Message 5 of 19
LyleHardin
Our AutoCAD drawings have it as 3/64" radius.
The circle is the same size as the text... 3/32" diameter.
Message 6 of 19
Sahay_R
And the circle needs to be 3/64"
Apologies for the delay!
Rina Sahay
Message 7 of 19
LyleHardin
Are you able to change the circle to that smaller size without the tail of the leader moving? That's the issue I'm having.
Message 8 of 19
Sahay_R
The only solution that I can see is to drag the middle blue dot on the leader up to the base of the field weld symbol. I have tried to re-create the symbol from scratch, but as soon as I add the all round symbol to the end of the base line, the leader just goes crazy.
Rina Sahay
Message 9 of 19
Sahay_R
@LyleHardin !! HOLD THE PRESSES!! GOT IT!!!!
Go into the Weld Symbol All Around family. Change the existing circle to Invisible Line. Create a visible concentric circle with the correct dimension. Load it into the Weld Symbol family, and then into the project.
RVT file attached.
Rina Sahay
Message 10 of 19
LyleHardin
Thank you very much! That will work for me.
Nice trick!
Message 11 of 19
LyleHardin
I spoke too soon.
I can't turn off my All Around symbol now.
Message 12 of 19
Edit the family, select both all-round circles and click on the small square button to the right of the Visible check box, then select Weld All around from the list of Visibility parameters.
Message 13 of 19
Do you have weld family for revit 2016?
Message 14 of 19
in reply to: ToanDN
Hi there,
I just recently followed this thread and I tried doing your suggestion of "edit the family, select both all-round circles and click on the small square button to the right of the Visible check box, then select Weld All around from the list of Visibility parameters."; however, I can't seem to make the "Weld Symbol-All Around" to be toggled off/on with respect to  the left/right side. I managed to edit the "Family Type Parameter" from "Graphics" to "Structural" for its "Visibility" to just match the properties of the "Weld Symbol-Field". I tried to re-load the "Weld Symbol-All Around" and repeated the assigning of visibility parameters but upon being loaded into a project, I still cannot toggle the "Weld Symbol-All Around" to turn off on neither side of the weld symbol. What am I missing to make it work?
Any help would be very much appreciated. Thank you very much.
Tags (2)
Message 15 of 19
in reply to: ToanDN
Oh, nvm. I got it already. Thanks!
Message 16 of 19
Thanks for the post...  I´ve used it metric and imperial scales with excellent results.
Message 17 of 19
How did you manage to edit fillet weld symbol to make it smaller? When I double clicked on it, it open edit family window for Weld Symbol-Fillet.rfa but I saw nothing. It was a blank. Thanks,
Message 18 of 19
Aditi.Rajavat
When I open the Tail symbol to edit, nothing shows up. There are no lines in the tail symbol, and I also cannot figure out how to get the arrows in accurate locations.
Message 19 of 19
LMeunier_TBI
I would love to know the answer to this, too.
Forma Design Contest
