Hi All,
I created an RBD isolator for my project as a new family.
In my section views I have this as follows:
My section is quite large, so for the sheet I had to create a "dependent" view with detailing, to divide the section by half.
Original at Top and Dependent at the bottom.
Here are the section views with the crop view option turned off to visualize the cropped region:
When I export this to AutoCAD, I noticed that the block which corresponds to my RBD Isolator for the original view is well defined, but the "dependent" creates a weird block like the image below:
Zoom at original
Zoom at dependent (rest is on the rigth of the view)
For the dependent elevation, the RBD Isolator is decomposed and a portion of the block is moved to the right.
What am I missing here?
Thanks in advance!
