Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Wall showing over structural coloumn in floorplan
3 REPLIES 3
tehbiskuit
231 Views, 3 Replies
i have tried everything i know from changing the coloumn offset to changing the family but the wall still show through the coloumn even though they are at the same level. here is the screenshot showing the coloumn that go beyond the wall (black) and the coloumn that are at the sam level (white)
Tags (2)
3 REPLIES 3
jay_colcombe
in reply to: tehbiskuit
If everything is correct as regards levels etc. then this is related to the Automatic Join Order
You can switch Join Order
And if the Materials are identical between the Wall and Column lines are removed
Jay Colcombe
Autodesk Certified Instructor
tehbiskuit
in reply to: jay_colcombe
im really thankful for the solution, but do i have to join manually all my coloumns and walls or is there a faster method?
jay_colcombe
They should automatically join but you can review Hidden Lines to see if this helps but will influence other items in the view?
Also when using then Switch Join Order you can do multiple using the Multiple Switch Tool - but again if you make them all the same material they do this automatically
Jay Colcombe
