Void Holes at Beam Ends Appear Cut in Project (Structural Framing Family)
aysegulcinar64
aysegulcinar64
I am using Revit 2025 and working with a Structural Framing family (beam). I created holes using Void Extrusions inside the family.
Inside the Family Editor everything looks correct. However, when I load the family into the project, the holes at the start and end of the beam appear partially cut (as if they are intersecting with the beam end).
What I did:
  • Created holes using Void Extrusion
  • Created reference planes 147 mm from the beam ends
  • Aligned and locked hole centers to those reference planes
  • Middle holes are distributed using EQ constraints
  • Double hole group works correctly
  • In the 5-hole configuration, the first and last holes appear cut in the project
  • Tried changing z Justification to Center
  • Tried Disallow Join / Unjoin Geometry
The family looks correct in the Family Editor, but in the project the holes near the beam ends shift or appear trimmed.
My questions:
  • What typically causes void holes in Structural Framing families to appear cut at the ends?
  • Is this related to Location Line / Justification behavior?
  • What is the correct way to constrain end holes in Structural Framing families so they remain stable in the project?
I have attached images for reference.
Thank you in advance.
Ahmed_M_Heteba
as per the family template of Structural beam / braces the extrusion should start and end at the second line not the first
try to adjust and see the results
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
ctm_mka
as Ahmed correctly stated, switch to the other ref planes, second is your "array offset" a type parameter?
lauri_barnhart
Hi @aysegulcinar64,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Or did the replies by @Ahmed_M_Heteba or @ctm_mka help solve your question? If so please click on the "Accept Solution" button so other members who might have the same question learn from your experience.
If you still need further assistance, please provide an update so we as community can help find a solution.
All the best,
Lauri | Community Manager
aysegulcinar64
I did as you said and it fixed the problem in the file, but when I tried opening a new file, it didn't work. So I deleted the Member Left reference plane and replaced it with a new one, locking the beam to that new plane. That fixed it.
aysegulcinar64
Yes, array offset is a type parameter.
