View References and Find Referring View
chauh
chauh
Is there a way to have the FIND REFERRING VIEW tool also search View References? Seems like an oversight to me.
Thanks.
Jason.P
If you go to the Referring view, the section cut mark, or elevation mark will be highlights. See jpg attached. They sometimes are tricky to see but you can change the colour to something a bit more catching if you want under options, graphics, selection. See jpg attached
Is that what you mean. Let me know if not.
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
youngTT6MK
It would be nice to be able to schedule them as well
Jason.P
There is....just follow this link. It is pretty good, then you can organize them how you want. Let me know if  you have trouble with it and I can help you out.
Create a View List | Revit Products | Autodesk Knowledge Network
Jason Peters
BIM Manager
youngTT6MK
Very much appreciate the response but Apologies, I meant schedule the "Referring Views" FOUND within a view. Not necessarily for model views but for a detail library of drafting views. It would be nice to be able to schedule "referring views" to ensure detail references stay true and are easy to track. I.E. when you copy a drafting view the view references (and their drafting views) come with it. So now, the library has been built but I have inherited a pretty big mess with all sorts of callout settings used in a wide variety of ways. It would be much easier to know where views are referenced rather than putting a pair of eyes on every instance to ensure it's format is correct; SIM, or TYP. or Opposite Hand, ETC.
