Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
viaduct too far from the origin
4 REPLIES 4
Sintecna_rws05
254 Views, 4 Replies
hi everyone, I'm drawing a viaduct and I'm using dynamo together with excel to model it. The tracking axis of the viaduct expressed in meters uses georeferenced coordinates so the viaduct will be positioned very far from the origin causing inaccuracies. How can I solve it?
4 REPLIES 4
Hi @Sintecna_rws05
You can define the project base point.
https://help.autodesk.com/view/RVT/2025/PTB/?guid=GUID-68611F67-ED48-4659-9C3B-59C5024CE5F2
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
Hi @Sintecna_rws05
Thanks a lot for posting your question to the forums!   Has the solution suggested by @andr3sant0s helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Late reply, you've probably moved on by now...
Since you're using Dynamo, provide a calculation to modify the resulting points by a common denominator to "move" the final form(s) closer to the origin. Alternatively, move the final forms closer to the origin after they are created.
Merely changing the Project Base Point does not place the elements closer to the Internal Origin which is what Revit is "concerned" about, keep the geometry of the model close to the origin to manage the required mathematical calculations in a way that ensures graphical representation is "easier" to produce.
Steve Stafford
Hi @Sintecna_rws05
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford helped with your issue?
Jonathan Hand
