07:12 AM
Hi to everybody,
I have a problem with the rebar module of Revit 2018/2020. I Would like to do a Varying rebar set with all the bar that follow the floor geometry. All rebar must to be of 3 meters. I've tried to use the "Varying rebar" command, and to set the constraints of rebar in the way of photo 1. The contraint number 1 is referenced tothe red line arc anche the constrain number two is reference to the same line with a offset of 3 meters.
Revit create all the rebar set but the rebars haven't the same length, you can see it in the second image.
How can i resolve this problem?? thank you very much!!
(IN THIS IMAGE YOU CAN SEE THAT THE BARS DON'T HAVE THE SAME LENGTH)
