Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Varying rebar set problem
2 REPLIES 2
jonasr_kirkhaug
600 Views, 2 Replies
Hi!
I have encountered a problem as I am not able to model my top u-bar (shape 21) correctly. I would like the bar to follow the inclined wall and use the same u-bar for all instances. If I use varying rebar set, the u-bars will follow the wall but have different leg lengths. I have tried editing the constraints of the bottom to correspond to the top wall face, however it seems it chooses the lowest point and applies that to all of the bars. Could anyone help?
I would like to have the counting of rebars intact in the IFC-export of rebars, thus not using the array.
2 REPLIES 2
could you share the file?
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Somehow when I redid this in the same way I described, it worked... Thanks for the reply!
