Variable floor thickness, up and bottom
Axel_JonssonPETNL
Axel_JonssonPETNL
I understand that I can use Modify Sub Elements to change the thickness on the top side, but this results in a flat bottom side. Is there a way to modify both sides of a floor element?
Here is a principal sketch of what I’m trying to achieve.
jay_colc
You could Edit or Create a new Slab Edge Profile and edit the Values to your needs?
Or a Model In-Place Sweep with a Floor Category
Jay Colcombe
Autodesk Certified Instructor
