Unsupported element error in cloud structural analysis
I am fairly new to Revit and am using it for my dissertation. I'm attempting to create a working analytical model of my building which I can then export to Robot and analyse, however I've been using the cloud analysis to quickly check whether the model is working and I keep getting unsupported element errors.
As I've never used Revit before I'm unsure what exactly is causing this. I've added boundary conditions to my columns and floors, do I also need to add these to every wall as this seems a bit excessive? I assumed using structural walls would transfer the loads to the columns without the need for extra boundary conditions.
AGYEMANG.OFOSU
Have you checked your analytical model to see whether your analytical elements are intersecting to create nodes at those joints.
If they don't, they will be unsupported
