Understanding error when exporting Precast .pxml file
stephen.spikings
Message 1 of 1
stephen.spikings
I am using Revit 2022 and am trying set up a process for exporting .pxml files from the Precast tools panel. I can export rebar only + simple walls, floor, framing and columns but as soon as I try to modify the host element manually with a fitting such as the supplied "Solid Wall - Bushing" I receive the error -
"The selection contains elements that cannot be exported aligned with the plane of the production table. Retry the export after adjusting the axis of the assembly".
I've tried manually matching the orientation which is produced automatically by the plugin with no luck. Does anyone know what principles I need to follow and what the error means?
Replies (0)
