I'm working on the roof framing for my bldg and I'm having difficulties with the Trusses. I'm using the OOTB Pratt 6 Panel Truss in Revit 2016. Is there a way to control to what edge the reference lines refer?
The first image below is taken from Acad (via a different project previously done using Acad). The solid lines are the truss members as the engineer want so see them. The dashed lines show what the Pratt Truss family is doing with the centerlines.
The second image shows what I'm getting in Revit when I place the truss and assign types to the various members (2x8 Top Chord etc). The green lines in the second image, show what I need the centerlines on the diagonal web members to look like. Basicaly the centerline of the diagonal should meet the bottom or top chord where the vertical member hits said bottom or top chord.
Also is there anyway to avoid having to select each member one at a timem unpin it, extend it, cope it & pin it again? Who in their right mind would think the would just end at right angles like that?
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
