Transfer Structural Model created in Structural Template to Architectural Template in Revit 2025
geteway2digitalindia
I have first created my model in Structural Template. Model comprises Pile/Pilecap/Tie Beam/Columns/Slabs/Beams/Staircase.
Thereafter I need to do the finishes - Walls/Ext-Int Plaster/Door-Window fixing/Railing.....
How to go ahead....
Do I need to transfer the Structural model to Architectural.
Step by Step guidance will be of help
Tom_Kunsman
Would recommend that you just link the structural model into the architecture model.
Can you please suggest the Steps to link the structural model into the architectural model
Tom_Kunsman
Go to a Coordination View in your model, from the Insert tab select Link Revit. Navigate to location of the structural model and click on OK. This workflow assumes you do not have any share coordinates set up.
Select the Structural Model, and from the Ribbon select the "Pin" command. If this is a workshared model, place the structural model on a Link-Structural workset (both Instance property and Type property).
