Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
To place Beams by grid projected into a floor sloaped surface
4 REPLIES 4
andreduarteAL3S4
501 Views, 4 Replies
Wrote a simple script in Dynamo.
Objective: To project structural beam by z axis into a surface floor.
This should work. Don´t know if their is any better geometry intersect. And don´t know why selected faces doesn´t work too.
I can´t follow the errors chain, and understand why caused it.
4 REPLIES 4
PavelAnd
in reply to: andreduarteAL3S4
Hi @andreduarteAL3S4 . You have empty lists in Geometry.IntersectAll node, that is why you are getting an error. You need to increase distance for Curve.Extrude node and use levels in Geometry.IntersectAll node to find all intersections betwen grids and selected surfsces.
Best regards, Pavel Plotitsyn.
andreduarteAL3S4
in reply to: PavelAnd
Hello @PavelAnd !
Thank for you answer and GIF! Somehow it still doesn t work, like you did on you computer.
Followed your footsteps, but I in my computer the node "Select Faces" is not working.
But the node "Select Face" is working fine...
PavelAnd
Did you click "Finish" after selecting faces? "Enter" on the keyboard will not work.
Pavel Plotitsyn
It was just that! My question was very dumb! thank you so much!
André Duarte, from Portugal
Forma Design Contest
Technology Administrators
