I'm trying to add a thickened slab edge to my floor slab. But when I attempt to use the profile that I made for this purpose, I get the old "Could not create Slab Edge" message.
My profile family is attached as well as a project file that I made for testing purposes (it has NOTHING but a slab).
Here's a sketch of what I'm needing it to look like -- the green lines are the slab before adding any thickened edge. The red lines are the boundary of the desired thickening.
Don Ireland
Engineering Design Technician
Solved by doni49. Go to Solution.
hello, im not sure if this correct, i tried it works. hope it helps. i attached back your files with amended slab edge. hope it helps. thanks
Thanks. Someone over at RevitForum.org was able to assist -- I saw their reply before yours and since it worked, I haven't tried your version.
Don Ireland
That link doesn't work. Not a solution.
Maybe just post the answer here instead of making us chase it down.
