Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
The multi rebar annotation creates dimension ticks, even when the bars are hidden
1 REPLY 1
174 Views, 1 Reply
The multi rebar annotation creates dimension ticks, even when the bars are hidden. I already figured out the cause, this happens when i displace a bar to make sure there's no clashes in the model. Is it possible to move single bars around in a set without having the multi rebar annotation doing this in my floor plans?
^the issue
^the actual spacing of bars is 100. The bar in between 114 and 85 got displaced to make room for the bars coming out of the column.
Labels (2)
1 REPLY 1
jay_colcombe
in reply to: 1031419
I can understand why its there as it is not a default spacing and needs to be identified and marked up accordingly, as a workaround:
Select the Multi-Rebar Tag -> Select Dimension -> go to "Properties Palette" change the "Equality Display" parameter to "Value".
Jay Colcombe
Autodesk Certified Instructor
Forma Design Contest
