Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Text size and dimension size in active view
2 REPLIES 2
390 Views, 2 Replies
I notice when i go to a sheet drawing and insert one of my elevation views that the text for the level indicators are slightly bigger from the text i am applying to the actual members in the elevation. Is this correct or should all the text be the same size? I know the title "Elevation" should be a little bigger.TEXT SIZE.PNG
2 REPLIES 2
You can always edit the level type and match the label size with the project text note size.
MostafaElashmawy
Usually, it's better to have all text in the drawing with same size.
However, some clients have different templates that they want to follow where some text are different in size.
so it depends on the requirement of the drawings owner.
Mostafa Elashmawy
