Tamas Batyi
Tamas Batyi
batyi_tamas
Tamas Batyi
batyi_tamas
Dear All,
Any suggestions to the following problem?
I have 2 structural column: 1st is an in place modell (as built data modelled directly so family is not an option), the 2nd (red) is an imported (binded link) construction design (it imports as directshape).
The cut works like "half space" not as range. It doesn't matter what I set to bottom or depth or both it always showing the whole column below cut plane.
KR,
Tamas Batyi
jay_colc
In the In-Place model you have the following option of a Structural Column Category has been selected, doe this make a difference?
Jay Colcombe
Autodesk Certified Instructor
batyi_tamas
Dear Jay Colcombe,
Thank you for the suggestion unfortunately it does not help. I have tried now the shape, material, precut parameter settings in different combination none of it caused change in this behaviour.
Additionally I have placed built-in slanted structural column and it has the same result (to check if it caused by direct shape or in place model). I tried with a slanted wall it works as expected only the range shown that is set. So I think structural column is affected by this (i guess this is not the intended behaviour).
KR,
Tamas
