Tags for linked IFC data
Sho_Gen
Message 1 of 1
Sho_Gen
Hi,everyone.
I linked an IFC data exported by a other BIM software of Steel Structures Design. I want to make tags for the linked IFC data to comfirm the information about level. However,
①I only need tags for beams and columns, but plates of joints are also recognized as structural framing so their tags are also generated when I make tags for all structural framing. I changed IFC options to that IfcPlate & IfcPlate are mapping with general model but it seems to not work.
By the way the parameters of plates are like this. Maybe ".NOTDEFINED" in IfcExportAs causes that.
②I cannot find any parameters that shows level information. Although IfcSpatialContainer shows the information about floor, I want more specific ones about geometric location like that upper face of a beam is "2FL-100". Maybe Dynamo is helpful for that situation but I am not familar with programming using Dynamo.
※I'd like to keep the IFC data linked rather than binding it because need it to be updated anytime
※I am using Revit2022. If it will be solved in Revit 2024, please tell me.
Hoping for any suggestions. Thanks a lot!
Replies (0)
