Tagging nested components in families
haydenwse
Message 1 of 8
haydenwse
I have created connection components that have other families nested in them.  I.e.. a bolt family nested into a plate family.  Is there any way to tag the nested component after it has been inserted into the project?
Replies (7)
Message 2 of 8
CoreyDaun
You cannot Tag components that are nested within a Family, UNLESS that nested family is marked as Shared. While in the Family Editor for the nested family, go to Family Category are Parameters, and check the box for "Shared" at the bottom.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 8
sean
So far so good.  Can anyone shed light on why the nested family disappears when the main family is loaded back into the building model?  And how to remedy this?
Message 4 of 8
sean
It was a visibility settings issue.  I had them set for the nested family to show on elevation, but not plan.  For some reason setting the nested family to 'shared' in the category settings changed the definitions for what view was what and I just had to redo the visibility settings in the nested family.  Probably has to do with the fact that the nested family is face-based.
Message 5 of 8
naleseFGVWC
This doesn't help me. All of the components are "shared" and it's still not tab-able.
Message 6 of 8
Dave_Texter
This did not work for me either.  Any updates would be greatly appreciated.
Message 7 of 8
ThijsSchade
I am also looking for the "automatic" tagging button for shared and nested families. The automatic tagging only works for top line families, not shared families. If you want to tag them you have to hover over tem and hit TAB untill you see it being selected. That works for me.
Message 8 of 8
medietri
TAB while tagging only works if the nested shared families are separated by a bit, doesn't work if they are close together unless I'm missing something.  Frustrating.
