Structure tab is missing
In my tabs the "structure" is missing. I think I deactived it in the installation process, but need ist now. How can I solve this?
  • Tab
mauricio_mssf
If your Revit for LT will not have this tab.
But if it's the full version, you can enable it.
  1. In the upper left corner of the screen, expand (Application Menu) and click Options.
  2. In the Options dialog box, in the left pane, select User Interface.
  3. In the Configure area, under Tools and analyses (as shown here), clear all of options that you do not want to use.
    If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
bcoole_1999
Observer
Observer
SOOO SIMPLE YET I FELT SOOOO STUPID WHEN I READ IT FROM HERE... THANK YOU SOOO MUCH
Sephies13
Community Visitor
Community Visitor
In Revit 2023, File->Options then follow above.
