Revit Structure Forum
Welcome to Autodeskโ€™s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Structural Rebar Tag. Adding dimensions to tag label parameters.
2 REPLIES 2
1157 Views, 2 Replies
I have a problem and hopefully someone could provide me with solution of it:
It the company that I work we have a system of tagging rebars. For example:
"O" represents the shape of rebar, 12 - bar diameter, and then goes the dimensions.
I would like to make the same tag system in Revit, but I struggle to insert the dimensions of rebar into the tag.
So far it is the closest tag I could make, but "1365" is the whole length of the bar, and is not the length that I want to present.
It should be as this:
There is no option to add the rebar dimensions to the tag:
Does anyone know how to insert the dimension into the tag label parameters?
Thank You in advance! ๐Ÿ˜Š
Labels (1)
2 REPLIES 2
Jamhmer_Oc
Hi @Anonymous
You can use shared parameters, as shown in the attached video.
https://autode.sk/3ym0RPQ
Jamhmer Oc
in reply to: Jamhmer_Oc
Thank You very much!
