Structural Opening by Face doesn't cut Structural Framing category instance
Antony.Roy
Message 1 of 10
Antony.Roy
Here's a demo of the issue.
I copied/pasted the lines but, trust me, even if I draw them by hand, it doesn't make any difference.
I moved a point randomly, but moving a line may or may not correct the issue.
Seems to be random.
I attached also the Revit file.
The structural opening is in there at the exact same location that you see in the video.
Video (Can't insert Screencast... don't know why right now... anyway):
https://autode.sk/30uYfR7
Replies (9)
Message 2 of 10
jvpantin2
Hi @Antony.Roy this issue is probably caused by the opening boundary location, it has to be inside or aligned with the boundary of the structural framing instance. I could do it both ways, inside and aligned, and works for me (take a look at the screen captures attached):
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Message 3 of 10
Antony.Roy
But it works when it is like this...
Message 4 of 10
arautio
I have not used that tool yet,  but if the above does not work on all occasions then the issue is similar to one that occurs sometimes when cutting geometry with voids.
The complexity of cutting in 3d means that on rare occasions the elements just align in such a way that the math required for the cut just can not be computed by the system. Usually adjusting the cutting element a tiny bit (as you have done) is the best solution to this type of problem.  I wrote an api that generates complex steel grating over any floor regardless of the floor profile, with lots of pipes and openings in a foor the final cut will sometime fail,  if this occurs it will bump the grating family 1/128" in x direction and attempts to cut again, then y direction, this repeats until successful. Usually works after only one bump though.
Message 5 of 10
Antony.Roy
@arautio when I move the opening around without changing the shape of it, sometimes it cuts... might be the same issue you encountered...
Message 6 of 10
hmunsell
have you tried the "Steel" options?
Howard Munsell
Message 7 of 10
Antony.Roy
@hmunsell Actually, that was not a bad idea but I tried it and I keep getting that message
Probably cause the family I create is too difference from a detail level to another...
That's a custom family that can flex too... Maybe that doesn't react too good with the steel modifiers
Message 8 of 10
hmunsell
when i try opening your model I get this error message....it says it was modified by a 3rd party updater. That could be part of the problem right there.
Howard Munsell
Message 9 of 10
Antony.Roy
This is an addin we developed.
Here's a new file in which you should not get the message and it's doing the same regarding the structural opening by face...
Message 10 of 10
MostafaElashmawy
Cut tools sometimes don't work properly with sloped and curved surfaces, there is always that locations where the cut is cutting the element in a way that's not accepted by Revit.
To reach the required result, you need to make two cuts as per below photo. the blue cut is using the small sloped line from your model, while the red cut, extend the slope a bit further.
I made it in attached file but in Revit 2021 version as I don't have 2020 installed. (check attached)
Mostafa Elashmawy
