structural material
structural material
structural material
I have a 2015 file from the engineer.
I can't change the structural material because it is greyed out.
Is there a solution besides my making the walls myself.
awes
Select Structure: EDIT and change material. Hope it helps.
Where is structure:  edit.
I am in the properties dialog box,  the structural material is greyed out.
I found what you discribed.
Thank you.
actrask
Excellent, where did you find it?
Can someone answer his question as
I am retired and it was almost 4 years ago.
Thank you.
terenceooi99
Observer
Observer
