Structural Connection Issue
I'm trying to attach structural connections to my beams but they wont work. This is the error I receive "A corresponding Shortening modifier for the Start/End extension Geometric position parameters was created. Start/End extension Geometric position parameters will not be available anymore.". This is for the beams that I changed the section shape and added structural section geometry to (I changed the section shape and added structural section geometry on the W27x84 and the W10x49).
I changed the section shape and added structural section geometry based on another post but it didn't seem to work (or I did it wrong).
Got this error when trying to attach the project file, so I attached some images instead, if you need something else just let me know . "The attachment's project with structural connection issue.rte content type (application/octet-stream) does not match its file extension and has been removed."
