structue tools
structue tools
joeiskandar1995
structue tools
joeiskandar1995
I created column rebars of one column
then copied the rebars to  25 columns.
Then I copied the rebars to another floor.
I got this attached picture.
I want to cut the top floor extensions of all 25 columns(50 rebars) since there is no slabs above this floor.
When I select the rebars of these columns I cant edit its constrain, I cant cut them, I cant align them....
how to cut these rebars as a group to reduce time? I cant find a link or a tutorial on this issue...
Can someone help?
YarUnderoaker
You can't reduce time in this case, Revit doesn't have good tools for complex rebar's serialization.
Btw your topic title is so abstract.
Jamhmer_Oc
No hay forma. Lo que puedes hacer es trabajar en una columna, colocarle sus dimensiones correctas del reforzamiento. Para luego crear un grupo con ese reforzamiento y ese grupo copiarlo a cada columna que tengas.
Jamhmer Oc
