Stirrup: Tag whole quantity
XXalessio.amodioXX
XXalessio.amodioXX
Hi all,
I would like to prepare a section annotating the whole number of stirrups in the entire project.
When I tag qauntity It is going to refer only to the set.
I woul like to achieve something like the pic I enclose.
Any ideas?
XXalessio.amodioXX
Hi all, no one can tell me how to proceed?
ovidiu_paunescu
Hi @XXalessio.amodioXX
Tags only extract parameter values from one selected element. In the case of rebar tags from only one rebar set or bar (if layout is single).
Multi-Rebar Annotation can dimension and tag multiple bars at the same time, but the sets should be oriented such that the dimension can be placed.
You can also use a rebar schedule where you hide all the borders, keep only the relevant info you want to display (e.g. quantity of stirrups - calculate totals) and overlay that section view in the sheet.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
