I want to use rebar with diameters 10, 12, 16, 18, 20, 22 how can i do that?
and if the only way to do that is by duplicating any existing loaded diameter, how can i get the standard properties for the new diameter like (standard bend diameter, standard hook bend diameter, stirrup/tie bend diameter)
Solved by Ahmed_Muharram. Go to Solution.
hi ahmed
the way to model anew size is by edit type then filling the data.
about the bend diameter and hook diameter use the Egyptian code of details or any other code you design with.
in ECP use these no. from 4 Diameter to 8 Diameter.
if it helped please mark as a solution.......
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
