Steel plate displayed without fillet
apdGAA5C
apdGAA5C
Hello, I'm trying to model curved steel plate, but I'm getting:
Instead of this:
In Advance Steel it looks normal:
I'm using Revit 2025.3. Any ideas how to fix it?
EDIT.1: If I make fillet radius to 100 instead of 610, it is working. Do you know any workaround? I need it in Revit. I'm getting: Modifiers not intersection the plate were deleted.
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi @apdGAA5C,
Thank you for reporting this issue!
This issue has been reviewed by Autodesk Technical Support and the Revit Product Design and Development Team and confirmed as a program code Change Request.
Findings of the investigation have been documented in the following public article:
https://knowledge.autodesk.com/article/Unable-to-create-steel-plates-with-certain-radius-in-Revit
Please, refer to it as a future reference for related news and workarounds!
To point the rest of the Revit Community to this resource, I will go ahead and mark this post as an "Accepted Solution" as it reflects the current status of the incident.
Please, accept our apologies for the inconvenience this issue has caused you using Revit!
I would also like to thank you for your patience and understanding, while the Revit product team reviews options for a possible improvement!
Best regards,
Zsolt Varga
Technical Support Specialist
Autodesk, Inc.
Revit Ideas | Screencast | Revit Help | AKN
